Sat, Nov 30, 9:21 AM CST
Subject: Trouble with saved poses.
MDibble ( ) posted Thu, 20 April 2000 at 11:30 AM ยท edited Wed, 27 November 2024 at 9:46 AM
Is anyone else having problems with using the poses in the Pose library? When I use one, it causes Poser 4 to stop functioning. I have the official patch and use a PC. :/ Mike
Nance ( ) posted Thu, 20 April 2000 at 12:25 PM
No probs here, similar setup. I'd try a quick replacement of your "poser.rsr" with the one from the last patch.
MDibble ( ) posted Thu, 20 April 2000 at 7:25 PM
I figured it out. Well, I solved the problem. If you set the poser.rsr to read-only, then start up Poser, it will freeze up when you apply a pose. Why this happens, I don't know. However, if poser.rsr isn't set to read-only, then Poser will inexplicably re-write the rsr after you exit the program. :/ Mike
Nance ( ) posted Thu, 20 April 2000 at 10:50 PM
Now that is odd. I thought a number of people had choosen to set their Poser.rsr to read only. Oh well, another one for the Work-Around files.
