Fri, Nov 29, 11:39 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: how do I set vicky hair to mil girl ?
digitalman ( ) posted Tue, 07 January 2003 at 7:34 PM · edited Fri, 29 November 2024 at 9:24 AM
evrytime I move the vicky hair to fit into mil girl after I move the body, the hair won't fit again. I know there is some way to set the parents from the menu, but when I click it from menu it only show the option to let you set the camera part instead of figure part.How can I switch ?
SAMS3D ( ) posted Wed, 08 January 2003 at 4:08 AM
Make sure that hair object is selected before you parent it. Sharen
digitalman ( ) posted Wed, 08 January 2003 at 6:45 AM
I did select the hair object, but when i try to parent it, the menu come out anf let me choose only cameras
TrekkieGrrrl ( ) posted Mon, 13 January 2003 at 6:14 AM
There are 2 ways of parenting things like hair. I've expirienced the same as you, no "figure 1" to use as a parent. Now I'm not on my Poser PC so I can't tell you which of the following 2 ways actually work G But choose the opposite of the one you've been using :o) 1.: Double-click on the hair and from that box that pops up, choose "set parent" 2.: Select the hair and go to the (object?) menu and choose Set Parent. One of them works, the other doesn't. Have no idea of why.
iamonk ( ) posted Mon, 13 January 2003 at 8:07 PM
I have had some luck using MAT pose edit to create a pose for hair that changes the ytrans and ztrans to suit the MilGirl.
