Thank You Porthos, she's very beautiful. JV
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
Ummmmm did u read what i said?? "however when i load up V2" I did try the OBJ file, got the same results as before :( what camera focal distance are you using? ah well... I hope it works for the rest of you, that is a very beautiful face... :) -=SimderZ=-
Sorry it hasn't worked out for you Sim - has anyone else had the same problem? I set the main camera to 100mm. I make sure that all dials in the head is set to zero including the Vicky morph dial.
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD
7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
I had to shut off the Victoria2 morph dial (change it to "0.000") to get it to work. (it's like the third morph dial down on the head.) Works far better on V1, and I was able to fire up other characters, dial their special morphs to 0 (For example, Handspan Studios' Audrey, which has a faerie/elf-like body)and apply this morph without incident. Again, thank you :) /P
I think the textures make a difference as I've had a "different" look using other textures. The texture used on the model is OXANA - ROMANTIC. by Byte Me OK!
7770
pendarian, sorry if you felt i was angry at you... my response wasn't meant to come across in that way.... :(
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
