Wed, Feb 26, 9:15 PM CST
Forum Moderators: RedPhantom
Subject: V3 full body morphs
marvlin ( ) posted Tue, 21 January 2003 at 5:14 PM ยท edited Wed, 26 February 2025 at 9:00 PM
I have just started playing around with the V3 figure I bought a few weeks ago, I purchased all the morphs available and have just tried applying some of the full body morphs. They are not working. I apply them and the window appears to lock up but windows itself continues to be free as it should be. Has any body else had this problem, if so how did you resolve it. A.M.D 2GHz DDR MOTHERBOARD Graphics= nvidia ge force4 128 meg TI4600 sound= C/LABS 128 PCI RAM= 1024MEG DDR H/DRIVE= 2x40GIG (STRIPED) 75% & 85% FREE ENVIRONMENT= WINDOWS XP HOME ADDITION PERIPHERALS= WACOM PEN TABLET, LOGITECH CORDLESS MOUSE. DRIVES= ATAPI CDRW & DVD ROM. OTHER APPLICATIONS= CORAL DRAW 10, PHOTOSHOP 7 & OFFICE XP. Vitual Memory = min. 10, max. 1800
i7 5930K 3.60Ghz | ASUS X99-S Motherboard | Crucial Ballistix Sport 32GB DDR4 2400MHz RAM | NVIDIA TitanX | Antec 1000w Power supply | Windows 10 x64 Home
SamTherapy ( ) posted Tue, 21 January 2003 at 5:22 PM
When does the window appear to lock up? If it's while you're applying the morphs, that's normal; they take a geological age to load - er, I mean inject. If it's another time, I dunno.
marvlin ( ) posted Tue, 21 January 2003 at 5:28 PM
I have previously applied all the morphs to the figure and saved it. It is when I try to apply a pose for example the pregnancy pose that things appear to go wrong, the figure doesn't change and then the application window locks up :o/
PabloS ( ) posted Tue, 21 January 2003 at 7:37 PM
I have the same problem in P5. The only way I get them to load is from P4. That doesn't mean someone else has found a solution.
rbtwhiz ( ) posted Tue, 21 January 2003 at 10:19 PM
"I have previously applied all the morphs to the figure and saved it. It is when I try to apply a pose for example the pregnancy pose that things appear to go wrong, the figure doesn't change and then the application window locks up :o/"
If you've "already applied all the morphs to the figure and saved it", there is no need to inject the morph again. The INJ poses (+) (eg. pregnancy) only inject the deltas and unhide the associated channel(s) for the morph. The reason "the figure doesn't change" is because the INJ/REM poses do not set a value; you must do that from the channel.
When "the application window locks up", have you waited any length of time (up to a couple minutes) to see if it is that the injection is being applied or do you try and immediately manipulate the figure?
-Rob
taco ( ) posted Tue, 21 January 2003 at 10:21 PM
I'm sure you know about the fixes on the V3 Daz pages. For me that problem was solved by loading V3 from the icon with the blue circle and making sure that V3 was the first character loaded.
marvlin ( ) posted Wed, 22 January 2003 at 2:24 PM
Hmmm! Didn't know about the fixes on the Daz3d page, will take a look! MARV
