Sat, Nov 23, 12:37 PM CST
Subject: Freestuff fixed
FWTempest ( ) posted Thu, 06 February 2003 at 9:36 AM · edited Sat, 23 November 2024 at 12:34 PM
Just thought that I'd let y'all know that I've uploaded the fix to my glassware problem, in the form of a new item. The new .zip contains a higher resolution snifter than the one provided earlier (Thanks, again, Ornlu and AgentSmith for posting renders of the model, and for pointing out the problem). It also has the schooner/goblet which is in the thumbnail image, but inadvertently left out of the zip - as well as four new vases. All should be in a high enough resolution that you can do close-up renders with them. If any more problems do arise with these models, please let me know. :) Thanks
FWTempest ( ) posted Thu, 06 February 2003 at 9:40 AM
Attached Link: Forgot to add the Linkage
oops!
e-artistree ( ) posted Thu, 06 February 2003 at 12:03 PM
Thank you for the nice models!
catlin_mc ( ) posted Thu, 06 February 2003 at 1:21 PM
You have done a lot of splendid work on your models FW, thank you for the new zip.
Ang25 ( ) posted Thu, 06 February 2003 at 2:06 PM
I can't wait to get home and get these. Thanks again, Angela
Ornlu ( ) posted Thu, 06 February 2003 at 2:23 PM
Thanks again, I needed that higher res snifter =)
tjohn ( ) posted Thu, 06 February 2003 at 2:59 PM
Thank you for sharing your work.
RobertJ ( ) posted Thu, 06 February 2003 at 3:30 PM
Thanks for the models, i did some HDRI experiments, it works well, that is another trick i can write down in the books.
Robert van der Veeke Basugasubasubasu Basugasubakuhaku Gasubakuhakuhaku!! "Better is the enemy of good enough." Dr. Mikoyan of the Mikoyan Gurevich Design Bureau.
FWTempest ( ) posted Thu, 06 February 2003 at 4:41 PM
RobertJ, that's awesome! Thanks, everyone, for the comments. They're not much...I'm just glad that I can give a little something back to the community.
Emberghost ( ) posted Thu, 06 February 2003 at 6:03 PM
Ok just one thing, Im not sure how you install these zip files. If someone would plz tell me the directory I import the zip files I would be very gratefull thx.
Ornlu ( ) posted Thu, 06 February 2003 at 9:55 PM
Any dir, you extract them, go into bryce, click file-import select one of the obj files and presto change-o you have it.
Arnold ( ) posted Fri, 07 February 2003 at 12:07 AM
As a newbe with only 6 weeks experience of Bryce, I have to say how impressed I am with your models I'm fascinated to know how the elongated "tulip shape" glass is modelled as I just can't see it in my mind's eye. What does HDRI stand for and how is it done (I realise it is the reflection of an external scene on a reflective object) If I'm being too cheeky, please tell me to mind my own business! The trouble is I'm yet another poor soul addicted to Bryce, who just can't wait to be able to create stuff like your majestic glassware. Arnold
FWTempest ( ) posted Fri, 07 February 2003 at 6:31 AM
Emberghost, Ornlu's right... Bryce isn't like Poser with it's rigid file structure complicating things. Just store your models wherever it's most convenient for you. In Bryce, use File > Import to bring them into Bryce. Arnold, Thanks.... at the risk of being rude, the easiest answer to your question would be to do a search in this forum for "HDRI" using the link at the bottom of the page. You'll find more than enough information to get you started.
TheBryster ( ) posted Fri, 07 February 2003 at 6:52 AM
Forum Moderator
Robert: Staggering - simply Staggering! The Bryster
