Mon, Jan 6, 6:56 PM CST
Subject: Thanks from the newbie
brholte ( ) posted Thu, 13 February 2003 at 6:43 PM · edited Sat, 04 January 2025 at 11:05 PM
Thank you all who helped me out with my lighting problem!! This is where I am at as of now thanks to you.
tjohn ( ) posted Thu, 13 February 2003 at 9:42 PM
Looking great!
Emberghost ( ) posted Thu, 13 February 2003 at 9:49 PM
What did you end up doing for the lighting I'm curious?
brholte ( ) posted Thu, 13 February 2003 at 10:06 PM
Well, it's rather simple actually. I have one radial light just outside the window by the upper left corner. and one more radial light smack-dab in the middle of the room with a really low intensity. Yep.... that's it. It turns out that somethings aren't as complicated as you make them out to be. now I have to fix the window so it doesn't look like a picture.
Doublecrash ( ) posted Fri, 14 February 2003 at 4:01 AM
Looks great! A big improvement from the first one! Now you can try to convert that radial outside into a volumetric spotlight, then using a lightdome inside, and then again checkin' the TrueAmbience & SoftShadows... :) This is what I did after seeing the works and reading the posts here... and I'm more addicted than ever... Stefano
Rayraz ( ) posted Fri, 14 February 2003 at 4:57 AM
Great improvement. You can now see what a great job you did on modelling the furniture. Try the light techniques Doublecrash said. It'll be a bit of fiddling before you get it right, but it's fun to play with those kind of lighting thingy's.
(_/)
SAMS3D ( ) posted Fri, 14 February 2003 at 7:18 AM
Oh this is much better...Sharen
brholte ( ) posted Fri, 14 February 2003 at 8:32 AM
thank you all. I will see what I can do with doublecrashe's ideas. I'm not sure I quite understand, but I will do my best.
pakled ( ) posted Fri, 14 February 2003 at 4:13 PM
it takes time, but lighting is often the most subtle thing, that yeilds the best results..
brholte ( ) posted Fri, 14 February 2003 at 5:03 PM
oh yes, lighting has improved my image alot. Here is an updated image!!! I am going to try to create streaming lightrays coming through the window. I am assuming that is what DC was talking about with the volumetric spotlight. I am still confused about what a light dome is though..... anyone know??
Rayraz ( ) posted Sat, 15 February 2003 at 2:43 AM
Attached Link: http://www.bryceanworlds.com/pages/simulated_radiosity1.html
A lightdome is a ball of radial lights. It creates a global-illumination effect. Check this tutorial: http://www.bryceanworlds.com/pages/simulated_radiosity1.html
(_/)
