Forum Moderators: RedPhantom
Hey Lululee :) What size is the template you are useing ? Sometimes its a matter of bad UV mapping by the original OBJ maker and remaping it helps. Other times its to small of a UV map . Some times its just the mesh it self that has too big gaps in places. That will cause all kinds of streaching across the gaps.
Occasionally if the stretching isn't too bad and you want to avoid having to change the UV templates you can reverse the stretching in your texture. In other words, you can pre-shrink that portion of the texture so that when it stretches it will approximate the correct proportions. It doesn't like that will do you much good here since the stretching is pretty severe and the jewel texture is fairly detailed.
...... Kendra
I 2nd Kendra! :) It's fascinating to see how different people approach the same issues. :) And it's great to learn new techniques!
Calypso Dreams... My Art- http://www.calypso-dreams.com
Does anyone know how to make textures for clothes that don't smear or stretch out of shape? Or are there any good tutorials on how to do this? If I scan in a jewel and put it onto a top it seems to me that it totally loses it's shape. Any help would be appreciated. Thanks in advance.
