Attached Link: http://www.senosoft.com/softp3do.php
Hi, the thumbnails is a file called .rsr if you are using Poser 4 or earlier and they are called .png for Poser pro and Poser 5. Depending on what Poser you use, you can get a .rsr to .png or png to rsr utility at Senosoft, it is called P3DoExplorer..... SharenIt is a free download and on that page you can see instructions on how to create your thumbnails either using .rsr or .png I reread my post above, and it sounds weird, so not to confuse you: .rsr is a thumbnail in your libraries folder with application Poser 4 or earlier .png is a thumbnail in your libraries folder with application Poser Pro Pack and Poser 5 Hope that explained it. Sharen
I'm using 1.5.5 Lyrra if that helps. If I remember right there were some added on plugins that I downloaded and installed at the same time. You might need those plugins or to upgrade p3do itself to do the png to rsr. It took me a while to figure out I had to edit the png then file save as to get the rsr. But the png's definitely show up in p3do.
Hi, I have been playing with some files and I am curious as to a program that converts my files to tumbnails with the actual picture of the finished product. When I save my faces or characters they are the preview image. How do I save thumbnails of the rendered image in the library?? I have looked through freestuff but have not come up with anything. Thanks, Annette
