Attached Link: http://larry.curiouslabs.com/poser/magnetTutorial/magnets.html
Yep, gotta use magnets. You can either parent the magnet to the chest, then select the zone to effect as both left and right collar, and reshape the zone to the breasts, or you can add a magnet to both collars seperately. Each has its advantages and disadvantages. Oh, and the weblink is for a magnet tutorial if you haven't worked with them before.Attached Link: http://www.eurus.dti.ne.jp/%7Emasasi/PROGRAM/PAE.html
Masa has a utility at Poser++ PAE&NeneLite it may be just what your looking for :)Content Advisory! This message contains nudity
Attached Link: http://www.philc.net/lowpolly1c.htm
Here is an example created in Poser and displayed as a Viewpoint animation.If there is a rotation or trans dial that you are using to make the figure go up and down, it is very easy to make the breast morphs be JCM and the movement will be automatic. What you cannot get with the single tie is lag or momentum. The link is real time. You can make a null channel add this in, or fine tune the key frames using the breast morphs directly.
In answer to lynnJonathan's question, yes I did make some PAE morphs for the P4 woman. It's pretty simple as you could use some of the standard movement morphs, and rename them with a PAE prefix to add them to PAE's system. If you've never seen the PAE in action you are lucky, because you don't know what you're missing in Poser 5. It's a shame Masa didn't develop it further as it would be a best-seller as a utility.
There were some walk designer files that added some bounce to walking V2 chars....
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Attached Link: nerd Walk Designer
I have animated the breast natural dials to get a decent bounce. Also nerd has a great walk designer set that keys the bouce. I have used it and is great for the bounce and walking in high heels. "From nerd promo You get all this! 18 Walk Blend Files 10 Walk Presets 2 Breast Morph Animated Poses >Content Advisory! This message contains nudity
Attached Link: keyframed bounces
You Do NOT need to use magnets for this just get a Vicky2 and key frame her "up and down" breast morphs in the Graph editorContent Advisory! This message contains nudity
Attached Link: more bouncing breasts
..................another exampleHmmm..."post your bouncing breasts animations here..." I'm sure I have one somewhere; an old sumo wrestler battle I believe...:-) (actually, I was testing out the PAE system mentioned above; worked pretty well) This must be one of the typical things one does with poser; trying to emulate soft body dynamics on mammelaries (sounds scientific, doesn't it?) :-)
In a Poser animation, is it possible to do bouncing breasts?? Or is that not possible?? Or should I just export the animation to a 3D program like 3DMax or Maya and animate the bouncing breasts there???
