A quick glance at the two tells me the v3 version's nose ridge is too wide and the jaw taper is not enough. The head is too short in the Y. All I can see for now.
For the mouth, try using the mouth smaller morph in the positive, then use the mouth narrow morph in the negative, along with upper lip up sides in reverse as well. Also, upper lip round in reverse, a teeny bit of the feline mouth should narrow the philtrum enough, without puffing out the tops of the upper lip too much. Lower lip narrow in reverse a bit as well should do it.
"Do not meddle in the affairs of cats, for they are subtle and will piss on your computer." -- Bruce Graham
