Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Attached Link: http://digitalbabes2.com/
Some one correct me if I'm wrong, but as I understand Poser 3 doesn't do Transperancy? If that is so, I'm afriad most of the "Realistic" hair is useless for you. If not then surf to the link :) Cheers, Axe.Attached Link: http://www.annsartgallery.com/links.html
Ah, you need to do some transmapping in Bryce.... Here are a few links to transmap textures in Bryce if you scroll to the bottom levt corner. Try out ALL of the tuts because each has a tip and none are complete. If you still have problems in Bryce after doing the tuts, come back and ask me. This is a bryce render of Judy/Koz.Already hit a snag with the tut - the tut assumes the hair is made up of lots of different meshes that you can select separately. The hair I'm using only shows up as one mesh in Bryce (I did export groups separately), so I can't just select that bit at the front. I don't know what other tuts to do - the link you gave only has one relating to hair.
Attached Link: http://www.castironflamingo.com/tutorial/grouper/index.html
Oh, and if you're going to render in Bryce, you should consider a freeware program called Grouper that helps convert your Poser model exports to something easier to manipulate in Bryce.There are a lot of things worse than dying, being afraid all the time would be one.
Great! Glad it helped. Arleen
I have Vicki 1 with hair. I would like to find some proper hair instead of these pieces of matted mud that come with Poser. Where can I find some free realistic-looking hair for V1? Any help much appreciated. Thanks.
