First of all, you have to actually click on the eye ball, not the figure. Each eyeball has it's own body (so to speak), so if you make sure you have selected the eyeball itself, then go to your materials editor...you should get it to work. Sharen Or maybe you want to click on the figure then go to the texture map from their. Up to you. Sharen
Each figure has it's own texture coordinates. Are you putting your new eyeball textures in the correct places? You can not simply create an eyeball texture and have it work unless it's in the proper spot in the file. You can take the texture template for your figure and texture just the eyeball area, leaving the rest of it blank, or you can put your new eyeball textures on a currently existing texture. Hope this makes sense! Cres
I need some help on poser 4 please. I need to change the eye's because the poser 4 eye's are these real dead fishy one's :P I try'ed to use some textures i found but i cant get em to work. I go to Matarials and the say edit eyeball and take wite as the colour and all but it wont work ! The other textures i try on other stuff alwasy works i just cant get the eye's to work. Plz help me out ~Gothic
