Sat, Nov 30, 11:06 AM CST
Subject: creating a photorealistic text question
---Gallego--- ( ) posted Fri, 23 May 2003 at 9:09 AM ยท edited Sat, 30 November 2024 at 11:01 AM
i'm reading the tutorial for creating a texture based on photos,but when you start in photoshop it says this: "Open your new body template and the full front shot of your model. Youll need to change the template from Indexed color to RGB color. Then make a new Layer, make a selection of any channel, and fill with black on the new Layer. This gives you a transparent template Layer." I don't get the part "make new layer,make selection of channel fill w black on the new layer blah blah....how do i do that?? can someone will be kind and explained to me?? thanx
JoeyAristophanes ( ) posted Fri, 23 May 2003 at 9:43 AM
I think he or she meant fill with black on the new Channel, although no clue why. If you want to keep the template isolated so you don't accidently move it, you just lock the layer, then delete to white when you're finished. You might want to try this one as well. Simple and very step-by-step. http://www.poserpros.com/forums/viewtopic.php?t=4030
tasquah ( ) posted Fri, 23 May 2003 at 9:48 AM
what photo program are you useing ?? In Adobe photoshop 7.0 you click layer than new. (3) Or just right click on the active layer and choose duplicate.(2) Your basicaly trying to make a copy of the layer so you can work with it and not muck up the original. The channels are the RGB ones ( Red , Green , Blue ) (1) I find the fill method a pain and you some times miss stuff so i use the polygonal lasso tool. Its kind of like a sewing machine you just start on a edge and follow along it clicking .
RHaseltine ( ) posted Fri, 23 May 2003 at 9:54 AM
You can also just set the template layer blending mode to multiply, which makes white effectively transparent.
Dizzie ( ) posted Fri, 23 May 2003 at 11:16 AM
it means add a new layer and flood fill it with black...
---Gallego--- ( ) posted Fri, 23 May 2003 at 11:35 AM
he fill it with black so he can have a transparent layer...i don't know what he means....it's done in photoshop 7.... Then make a new Layer, make a selection of any channel, and fill with black on the new Layer. This gives you a transparent template Layer. I usually name this Layer Template. Go to your photo, and duplicate it to your template file. Then save this under a new name. Lets use the name TutorialBody.psd as our working name" i'm still confused on the "transparent template"
RHaseltine ( ) posted Fri, 23 May 2003 at 12:58 PM
It seems to want you to make a layer which shows the black lines from the template, but lets you see the background (on which, presumably, you are going to be painting your texture) through it. Because the template is black and white all of the colour channels in your Photoshop file will be the same. Loading one of them as a selection, creating an empty layer and filling with black will give you black outlines surrounded by transparency. But as I said, just bringing the template in as a layer (drag it in with the pointer, with shift held down so that it fits in the same position) and setting the blend mode to Multiply will do the same for less effort.
---Gallego--- ( ) posted Fri, 23 May 2003 at 6:36 PM
thanx
