Sat, Nov 23, 4:42 AM CST
Subject: Texture
DarkEden ( ) posted Tue, 20 June 2000 at 9:22 AM ยท edited Wed, 24 July 2024 at 1:49 PM
I have a question... And many more to come... Is it possible to make a Texture animated? couse i'm working on the dude you see here and i wanna make the fire move... but is that possible in Poser? The T-man
jeffheater ( ) posted Tue, 20 June 2000 at 9:37 AM
I just tried an animated gif but it did'n work, maby try a reflection and bump map and see if that can give you the effect your after Jeff
CharlieBrown ( ) posted Tue, 20 June 2000 at 11:27 AM
Yeah, I think the only way you can do this is to fake it with a reflection map and a moving light source to shift the reflections around. I'm not even sure that would work, but I think it's about the closest you can get without doing separate animations for each part, using different textures, and then compositing the whole thing in a video editing program
arabinowitz ( ) posted Tue, 20 June 2000 at 12:50 PM
If you have a program like after effects (or avid) it can be done. You need to make the limbs Blue and then blue screen them out in after effects, and put some fire in the layer behind it. (I create a full screen of fire for this and then use it as the back layer). If you have any program that can key out (remove) a specific color this can be done. Aharon
kyrin ( ) posted Tue, 20 June 2000 at 3:38 PM
You can't do it in Poser because it doesn't support AVI or animations as textures. In 3Ds Max all I'd have to do is use an AVI file.
jschoen ( ) posted Wed, 21 June 2000 at 12:32 AM
Poser doesn't even allow morphing textures. :(
