Thu, Feb 27, 9:40 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 8:38 am)
Subject: Tenten on V3 Tutorial uploaded
Yamato ( ) posted Sat, 09 August 2003 at 5:29 PM · edited Thu, 27 February 2025 at 7:32 AM
Attached Link: http://www.juno.dti.ne.jp/~yamato-k/
Tutorial how make v2v3 combined model was uploaded. TentenV3 has V2 head and V3 body. Because of copy-right problems, I couldn't release this model. So I decided to upload a tutorial of making process. I think it's not easy for beginners. Import/Export option of Poser, Building up grouping obj, Editing cr2.....etc. If you like Tenten and don't mind these process. Try it ! (Required Pre-installed TentenN) You will find two download files in the tutorial Don't miss them. As you noticed. It's not only for Tenten but for all Vicky2 characters. If you want, You can transplant favorite Vicky2 model to Vic3 body.
VI_Knight ( ) posted Sat, 09 August 2003 at 5:57 PM
Thanks Yamato. on my way to download
joffry ( ) posted Sat, 09 August 2003 at 6:30 PM
thank you. Looks very clear and even i should be able to do it. thank you
galactron22 ( ) posted Sat, 09 August 2003 at 7:33 PM
I bow to you and say "I'm not worthy!!!".
I have two questions:
1)how did you fit the DAZ3D Diamonds set to fit the V3 Body?
2)Where can we get the fishbwl set?
Thanks for the tutorial I'll put it to good use.
Ask me a question, and I'll give you an answer.
igohigh ( ) posted Sat, 09 August 2003 at 7:43 PM
OMG!! I love her new bra! But dosen't that tickle her cha-chas?? The return of the SeaMonkey Jewelry fade!
Spit ( ) posted Sat, 09 August 2003 at 8:58 PM
This is written so well! Thank you very very very much! And thank you for the neck object. This makes the process so much easier for people like me!
lalverson ( ) posted Sat, 09 August 2003 at 10:53 PM
Having Just followed the steps and and done this I find it is a KICK ASS THING!! Thank you sir!!!
bijouchat ( ) posted Sun, 10 August 2003 at 8:12 AM
This is fabulous, thank you!!
Yamato ( ) posted Sun, 10 August 2003 at 10:45 AM
Thank you for comments. I revised the tutorial. I forgot a important step. Before exporting V2 head obj, You must set Hdvictoria2 MT parameter at zero. If you've already done with this MT. Copy Hdvictoria2 to TentenV3.cr2 by Morphmanager and set parameter -1.000. Ansewers for questions 1)Diamonds : Rewriting cr2 and little deforming obj to fit V3 body. After deforming, apply deformed obj to V3Blank.cr2. And copy material from original Diamond cr2s to new cr2. One point TIPS : checking off Hip properties Bend option. 2)Fishbwl : Do you need it? I made it for temporaly use. So I made it in a halfhearted way. If I'll get many requests, Imay remake it for releasing.
swfreeman ( ) posted Sun, 10 August 2003 at 11:34 AM
i have to thank you so much... i wanted one of your morphs so badly for v3.. the tutorial was very well written and easy to work with . i got tenten working after the first try :D only the eyes where a bit to far upwards and back..but nothing you could not re-adjust (i think it could be something with the morphs..but i have set them to 0) wheee... im still amazed :D thank you so much.. btw.. what about v3 versions of ranran (my alltime favourite)..or linlin? ok.. i know the geometries are complete different... but i would be very amazed about a vicky version of one of them.. :D
swfreeman ( ) posted Sun, 10 August 2003 at 11:58 AM
im getting this eye problem when i apply a pose too... lock actor helps,but i want to know what this causes..
compiler ( ) posted Sun, 10 August 2003 at 12:11 PM
I definitely loved the fishbowl and the fishbowl bra you used in your image for the swimsuit exhibition. I really wish you'd make them available, if it's not too much work for you. And many thanks for the tutorial, too.
Yamato ( ) posted Sun, 10 August 2003 at 12:15 PM
Hi. Did you copy bothe eyes MTs from TentenN? TentenN has eye position ajusting MT (named Lefteye02 and Righteye02) If you ajusted the position by Y and Z tran. When you apply pose, Eyes goes back to original position.
igohigh ( ) posted Sun, 10 August 2003 at 12:28 PM
Oh PLEASE yes on the fishbowl! The fishbowl and bra is a wonderfull and cleaver idea! (I bet Tenten gets a thrill out of it too ;)
pizazz ( ) posted Sun, 10 August 2003 at 8:42 PM
PLEASE please on the diamonds. I've begged Anton to do something similar or rework them for V3.
