Like Dagon said, it is not a conforming item. When you have conforemd it to V3 or any other figure and it does weird things just click Conform to again and select None from the list. That will put your item back into it's default position. With Vicki's changing Ponytail you simply select the body or the base of the hair, go to Figure - Set Figure Parent and select the head of your model. After that the hair stays in place when you pose your model.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
When you like to use the Ponytail with SaraSpriteling it's really easy to make it fit.
Load the hair, then you go to the SaraSpriteling Pose folder and click with the hair selected on !Deform Libary Hair and after that (with still the hair selected) on !!Instant Human or !!Instant Elfling (depends on what morph you have used on Sara) and that will put Vicki's Changing Ponytail perfectly on her head. All you need to do is parent it to her head that it stays there when you move her around but you do not have to use the dials to get it into position.
Btw, using this poses will make every hairfile fit to Sara.
Every
Assange
how can i do to conform the daz changing ponytail to v3?? every time i put conform..it goes to the floor!! i've tried on sara spititelling and is the same!!! cant pick up the hair from the floor!! PLEASE HELP!!
