Finally a USEFULL Judy! It looks awesome. I hope you find a way to distribute it :o)
The Injections would work the same for Judy as they would for V3. They work on the open file and that is not compressed. I think you mean that your problem is - How to I get slots/channels into a Judy.cr2 for my Injection poses to work with? I am about certain that MM4/MC will not open the .cz2, so using it would mean that a user would have to have an uncompressed judy.cr2 to use with your file that has the target channels. This would mean that you ould need to explain how to uncompress the library files for the library. I suggest by passing this altogether: Why not go for older technology? Strip a JUDY.cr2 of its shape morphs and provide it with your morphs and any others that may be needed. You can totally strip the head of all morphs, since you intend on replacing it with V3 head anyway. The size should not be much different.
I may get use out of Judy yet, if she can look like that! She's beautiful >^^< Judy needs some smoothing around the edges though. Her polys are showing >^~ Seriously though, TEnten's face is so lovely and smooth, but Judy's body, while it can assume a pleasing shape, still has those poly angles on her curves.
hmm yamato.. really, WHY do you need to ask ? tenten is a marvelous model in all its versions, as for old cancan and ranran.. i saw recently on forums peopel complaining abotu judy always remaining judy no atter what morph and textures peopel tried to apply.. i guess that you managed the impossible: do something with judy, with a personnal look/touch i had always been very fond of your characters and i think i am not the only one.. they are cuty, with shining/luminou face, adorable girls ! even the custom joint parameters for P4 contributed the old P4f not to die, i think ! again, thanx for all your work
Thank you Jaager and all. I can find a key to the solution of my problem. By using specialized cr2 files, I'll be able to add my MTs into TentenP5.cr2. Only injection of full-body morph channel remain..... Anyway I'll make final touch for some MTs by next weekend. And I'll release Tsuta pack 2 for V3 and Judy at the same time. Thanks all
