Sat, Nov 23, 5:11 AM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: Will anims in Poser go straight into swift or vector?
Mason ( ) posted Tue, 11 July 2000 at 5:46 PM · edited Fri, 01 November 2024 at 2:23 PM
If I want to make an actual animation, do I have to put it through 3d studio or can I export it out of Poser somehow?
arcady ( ) posted Wed, 12 July 2000 at 1:39 PM
You can export it out but it will be exporting a rastor format (animated gif or avi) and not vector images. Swift3d and Vecta3d deal in importing 3ds or dxf files, then making the animation there. So you couldn't do a walk animation unless you exported each frame as a seperate 3ds file.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
zorger ( ) posted Thu, 13 July 2000 at 1:23 PM
I was very disappointed when I got my hands on both Swift and Vecta. I was hoping to export poser chacters out to Flash cartoons and found both products useless for this. The best way I found is to import the images from poser into flash a frame at a trace them into vectors. here is an animation made this way: http://www.vidivox.com/showpages/s18zorger.htm
JOE LE GECKO ( ) posted Thu, 27 July 2000 at 1:45 AM
Export your animation from Poser by selecting the whole animation and making each frame a different 3ds file. Once in vecta, open the first file : xxxx001.3ds and a window will pop up, asking you to import it at a sequence or a single file. Chosse sequence, pose your model ( only the first frame will be displayed ) in the 3d view. When you will export it to swf, vecta will render each frame after the other one and voila, you got your anim ( but huge size! ). You'll have to optimize it in flash...
