Concerning my post in the Cinema forum: To YL: The render quality difference is because of two simple things: First Vue uses ambient light, which makes a flat look. And I used no ambient light in Cinema. Second I used raytraced soft shadows in Vue and mapped soft shadows in Cinema. Therefore the shadows in the Vue render are not as sharp as in Cinema. This was no beauty contest between Cin and Vue but a time comparison with more or less standard settings for each prog, without a thousand tweaks and trys to optimized something. I use Vue Pro only since 4 days and I never had Vue desprit before. So with exception of the Vue 4 Demo I am completly new to this program.
Videodv, you managed to get rid the black around the trees, great!! You said you exported to .3ds; why didnt you convert it to .c4d format?
Absinthe you said XFrog trees rendered slower than Vue Pro Trees; how much slower? Can you render a similar scene using XFrog (I know you cant make an exact match) and post the numbers?
Dave
OK a quick update as I have to get ready to work I have just done a quick export of the cherry tree at the following res mesh 30.50meg and texture size 4936, and even with the camera right in the tree it was just about spot on with the leaves. Perfect! I think if you have a low spec machine like mine it is better to export the parts indevidualy so you get a better export, and go for as high a res as you can get away with. Things are realy starting to look up, will post new results tomorrow. (will try c4d format too, but seems to work fine with 3ds!) Videodv.
I used ozone for the atmosphere, and the rest was exported from pro.
One thing to note; not all terrain maps generated by pro look as good as the ones presented in this thread. It seems pro doesn't use the bump settings for a material when it generates the map. For some terrain materials, the bump settings are very important. Sure hope this is something e-on can change.
Ahahah Absinthe, your last comparison with C4D was very funny (posted in C4D forum not here) : the render quality was completely different between your Vue and C4D pictures. Please try to compare things which are comparable. Not an easy task.
