Sun, Dec 1, 2:56 AM CST
Subject: More Maping problems
rx2web ( ) posted Sun, 30 July 2000 at 4:40 PM ยท edited Thu, 28 November 2024 at 12:38 PM
I have an object wavefront.obj file that I exported from 3dStudioMAX for use in poser. I can bring it into power just fine and use it. But now I want to make a texture and a transmap for it. So I open it up with mapmagic or UVMapper, but all that appears is a blank white screen. Hard to export a texture mapping with no lines.... Help? Am I doing something wrong?
Lemurtek ( ) posted Sun, 30 July 2000 at 4:53 PM
You need to create a UV map for it. Look in the edit menu for the new UV map, then select a type, planar, box etc. You may have to experiment to get one that works well with your object. Regards- Lemurtek
rx2web ( ) posted Sun, 30 July 2000 at 4:54 PM
Gotcha i think I saw that option....Will try again
Kalypso ( ) posted Sun, 30 July 2000 at 5:32 PM
Site Admin
Don't forget to resave your object after mapping it the way you want otherwise the map won't work on it! Been there done that :)
