Thanks PhilC and Little_Dragon - I'll try both suggestions. Another thing I've noticed is that even though I line up the shirt object so that it is in the correct relative position with the character before I go into the setup room when I selct the characters bone structure it is displaced in the y axis by about .005. Don't know what is going on there.
The bone structure is probably displaced because the character's yTrans value isn't zero. For some reason, a lot of figures are like that by default. I prepare the donor figure beforehand. That means disabling IK, zeroing all the joints (with the Joint Editor), making sure all the trans values for Body and hip are set to zero, and memorizing these settings (Edit menu --> Memorize --> Figure). Once this is done, save it to the Library and then load that in the Setup Room for your bone structure. You might also want to strip all the morphs from the donor figure, by hand or with Morph Manager, since they probably won't be compatible with the clothing mesh you're poserizing, and you'd have to remove them afterward anyway.
I'd really appreciate if someone can give me a few clues on what might be going wrong. I've been through the process half a dozen times including remaking the shirt object and the result is always exactly the same except sometimes the distortion twist occurs on the opposite side of the body. Previously I made a pair of shorts for Sammy and there were no problems of this kind at all.
