Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
You dont have to uninstall Vue 4 or Mover 4 , but you have to install Mover 4 for Vue Pro as well - with your Mover 4 serial number. Be aware, that dynamic Poser effects (hair and clothes) are not supported at the moment. Something a lot of people do oversee these days. "Worth the money"? Well, depends. I think it is, others say not. All a question what you want to do with it and what you expect. For me it is a big progress, compared to Vue 4. Plant editor, automatic update of modified imported objects (Poser scenes for example) to name only a few new things. But like buying a car, what does it mean "worth the money"? Very different things.
In the beginning i didn't installed Mover 4 because i was not sure either. Then i decided to simply try it. As far as i remember there is a Mover 4 for Pro installer on the CD. I started that and entered my Mover 4 serial number, the only one i had. Tata, it worked. I think i read it somewhere, that Mover 4 is Mover 4 - one serial number. Guitta, maybe you simply try it out as well. And tell us. Walther
Here is a step by step tutorial for correct installation of Mover for both Vues: 1. Install Vue d'Esprit (if it isn't already there); 2. Install Mover 4 for Vue d'Esprit, from your Mover 4 source (CD or download) 3. If you have a network, install the RenderMoo of Mover 4 for Vue d'Esprit on ALL the computers in your network including the computer you have Vue d'Esprit installed on (if you want to use it for rendering and not only as Vue host) 4. Install Vue Pro in a different directory than Vue d'Esprit. 5. If you have a network, install the RenderMoo for Vue Pro on ALL the computers in your network including the computer you have Vue Pro installed on (if you want to use it for rendering and not only as Vue host). Do not worry, they are a different breed than those of Vue d'Esprit, so they won't mix and create unwanted cattle ;-) 6. Install Mover 4 for Vue Pro FROM THE VUE PRO CD. This is a fundamental step. DO NOT install it from the original Mover 4 CD or download. Use only the copy of Mover 4 that is on your Vue Pro CD. When asked, enter the same serial number that your Mover 4 copy came with. It will work for Vue Pro too, it is absolutely legal, and won't create any problem. The two copies of Mover will share the same serial number (because Mover 4 for Pro is a free update for registered Mover 4 users), but they will act independently. 7. Install the RenderMoo for Mover 4 for Vue Pro FROM THE VUE PRO CD. Same warning as in point 6. Again, do not worry as the breeds won't mix and the Moo installation will aim only where it's supposed to aim. 8. Run the update voice from Vue Pro menu and let the Internet update your Vue Pro and RenderMoos to the latest version. Whoa that's all... I wonder how many times I'll have to rewrite this tut... as it's not the first time that I have to do it ;-) Orio
Hi I was thinking about buying Vue4 professional because i read somewhere you can import from poser5 with it but does vue pro work with mover 4? Thanks........asmith
