Sun, Dec 1, 4:31 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Render separate script question
iamonk ( ) posted Mon, 01 December 2003 at 3:40 PM · edited Sun, 01 December 2024 at 3:19 PM
I run P5. I recently tried a script I found in Freestuff. I guess it was to render figures separate from each other. What happened is it got stuck in some sort of loop, rendering one figure over and over. I had to shut P5 down from the task manager. Same thing happens each time I run the script. Huh?
ockham ( ) posted Tue, 02 December 2003 at 11:43 AM
Which script exactly?
My python page
My ShareCG freebies
iamonk ( ) posted Tue, 02 December 2003 at 4:29 PM
It was a "render separate.py" by markdc. I've been playing with some of your and other's scripts. This was the only one I had a problem with. Just wondering if anyone had an issue with it or is it just me.
ockham ( ) posted Tue, 02 December 2003 at 4:55 PM
That script doesn't seem to be in freestuff now.... Maybe it was written before P5. Some of the P4 scripts, especially those using the TkInter panels, will do odd things in P5.
My python page
My ShareCG freebies
iamonk ( ) posted Tue, 02 December 2003 at 5:14 PM
Thanks
