Fri, Nov 29, 2:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: bending the knees the right way
JayCeeRD ( ) posted Sun, 21 December 2003 at 1:30 AM · edited Fri, 08 November 2024 at 5:16 PM
Hi, I was wondering if there was some procedure in bending a character's knees properly. I'm trying to get a character to squat and when I try to pose it, the knees keep bending the wrong way. I try just bringing the hips down on the Y axis, but the knees buckle and go the wrong way. Then, I try to bring the feet up toward the hips, but the same thing happens. I would think that if I twisted the thighs outward a little, then the knees would bend the right way when the hips come down, but they didn't. Any ideas? Thanks for any help, john...
Lucy_Fur ( ) posted Sun, 21 December 2003 at 2:14 AM
Are the legs' Inverse Kinetics turned off??
PheonixRising ( ) posted Sun, 21 December 2003 at 2:15 AM
That can happen while IK chains are still on. Turn of Inverse Kinematics for the legs. Then try psong without IK. If you prefer to use IK. Put the figure into more of a squat pose before turning IK back on.
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
geep ( ) posted Sun, 21 December 2003 at 2:25 AM
The shin and the thigh must have a slight bend in the correct direction for this to work properly. Try (with IK ON) lowering the hip slightly ... then adjust the "bend", "side-side", and "twist" for a natural position. Do this for both the thigh and the shin on both legs. Now, when IK is ON and you raise or lower the hip, the legs should behave properly. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 21 December 2003 at 2:29 AM
You might find some useful information HERE. Check Page 3. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 21 December 2003 at 2:33 AM
THIS ONE is probably better. See Page 4. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
