Sat, Nov 23, 5:02 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Morph tool
ockham ( ) posted Sat, 27 December 2003 at 1:54 PM · edited Sat, 23 November 2024 at 4:57 PM
Attached Link: http://ockhamsbungalow.com/Python/MorphTools.zip
From a suggestion by Migal. Set up groups, modify them.
My python page
My ShareCG freebies
andygraph ( ) posted Tue, 30 December 2003 at 7:03 PM
Can you create a python for split (x,y,z axes ) a props (morph target) ? thx; Andygraph
ockham ( ) posted Tue, 30 December 2003 at 9:22 PM
Attached Link: http://ockhamsbungalow.com/Python/MTbyGroup.zip
I think this script, which already exists, will serve. It's not fully automatic, but it will let you isolate the left or right half of a MT.
My python page
My ShareCG freebies
ockham ( ) posted Tue, 30 December 2003 at 9:23 PM
To split a prop, the Grouping tool by itself should work..... no Python needed.
My python page
My ShareCG freebies
andygraph ( ) posted Wed, 31 December 2003 at 6:03 AM
many thx ockham ;-) and happy new year !!
andygraph ( ) posted Wed, 31 December 2003 at 6:19 AM
I have see the Grouping tool but i don't have see any option for split a props (mirror effect)
ockham ( ) posted Wed, 31 December 2003 at 10:48 AM
Well, the Grouping tool doesn't split automatically, but you can use it to select one side, then Spawn Prop. This won't work if the mesh isn't built right.... if the facets aren't divided at the centerline, there's nothing you can do about it.
My python page
My ShareCG freebies
andygraph ( ) posted Tue, 10 January 2006 at 6:05 AM
it's possible add this new feature : scale on x, y, z thx for feedback; Andygraph
AtelierAriel ( ) posted Fri, 20 January 2006 at 12:21 PM
Ockham? Did you take your zip down? Just tried and got a 404. Also, could you use this to add morphs to hair? Without having to add magnets? And if you create groups then run the script, does the script pick up the groups so that you can choose one and work on it? And...will it work on .hr2, not just .cr2? This would be so great because I'm always wanting to add morphs to hair and can't always get what I want with magnets.
