Fri, Nov 29, 4:02 PM CST
Subject: How do remove IKs from a cr2???
insomniaworks ( ) posted Thu, 08 January 2004 at 3:08 PM ยท edited Fri, 29 November 2024 at 3:50 PM
Where in the cr2 are the inverse kenetics. How do I remove them from a cr2? Thank You Marty
shadownet ( ) posted Thu, 08 January 2004 at 3:36 PM
Look for inkyChain section just before default pick near end of cr2
example might look something like:
inkyChain LeftLeg
off
name LeftLeg
addLink lThigh:1
addLink lShin:1
goal lFoot:1
linkWeight 0 1
linkWeight 1 0.2
inkyChain RightLeg
off
name RightLeg
addLink rThigh:1
addLink rShin:1
goal rFoot:1
linkWeight 0 1
linkWeight 1 0.2
inkyChain LeftHand
off
name LeftHand
addLink lShldr:1
addLink lForeArm:1
goal lHand:1
linkWeight 0 1
linkWeight 1 0.2
inkyChain RightHand
off
name RightHand
addLink rShldr:1
addLink rForeArm:1
goal rHand:1
linkWeight 0 1
linkWeight 1 0.2
shadownet ( ) posted Thu, 08 January 2004 at 3:38 PM
Hightlight and remove entire section. Be sure and work from a backup copy. Some figures do better with IK section left intact, otherwise the feet get screwed up when loading or when trying to conform a clothing figure to it. Never had a prob removing IK from clothing items.
lesbentley ( ) posted Thu, 08 January 2004 at 5:36 PM
I dislike having leg IK on by default when a character is loaded, but IK can somtimes be usefull. Rather than remove IK completely I prefer to disable its default On status. I do this by opening the cr2 in a text editor. I do a search for 'Leg' which takes me to the 'inkyChain' section of the cr2, and for the right and left leg I change I change 'on' to 'off'. I then do a global search and replace of 'Leg' with 'LegG'. Now the leg IK is off by default, but can be turned back on through 'Figure>Use Inverse Kinematics'.
There is one last step, as Shadownet pointed out "the feet get screwed up" this is because the translation values for the feet are none zero in some figures. You have to go to the translate channels for the feet and set them to:
k  0  0
Usually it is only the translateX channel that is none zero. Also set the initValue line to zero.
shadownet ( ) posted Thu, 08 January 2004 at 5:43 PM
Smacks forehead, oh yeah, I had forgotten that one about zeroing the feet to fix the leg prob. Thanks. :O)
Ajax ( ) posted Thu, 08 January 2004 at 5:59 PM
The fast way to delete IK is to open the hierarchy window in Poser and select the IK chain and press the delete button. It's much easier than messing about with the cr2 text (and this is coming from a guy who really likes messing about with cr2 text).
lesbentley ( ) posted Mon, 12 January 2004 at 4:22 PM
Great tip for deleting IK, thanks Ajax!
shadownet ( ) posted Mon, 12 January 2004 at 4:40 PM
Yes, thanks from me also. I did not know you could do that. :O)
Ajax ( ) posted Tue, 13 January 2004 at 3:53 AM
