Vue F.A.Q (Last Updated: 2025 Feb 23 3:59 pm)
Global Transparency should be set to 100% Variable Transparency should be turned on. In your Transparency Map, make sure that all transparent areas are completely white. Fade Out should be set to 0% (totally clear) CAUTION: Vue cannot render more than 5 layers of transparency on top of one another. At the 6th layer, all you will get is the fade out color (blue by default) -SMT
I have noticed from time to time, a bug in Vue where one of the edges of a transparency mapped plane will show up as a very thin line when rendered. It doesn't happen all the time, and I'm not sure what causes it, but it can be very annoying as I have to get rid of it in post touch-up. -SMT
heyas; dunno. here's a tip though: do NOT use a jpg for the trans map. they have a tendancy to make the blacks un-black, and mess up the flat areas of colour with those lossy thingies. use a 256-colour greyscale gif. (or tif... shoot, now i cant remember... vue doesn't do gifs, does it?) hmmm... it DOES look like a refraction problem. i can see the top darkening looks like the underside of the water wave things...
Hello All, Narrowed my problem down to (as was suggested) to the transparency refraction. I upped it to 1.30 and the "blues" went away. However, if I increase the highlight, it comes back. I'll try bloodsong's suggestion of using other types of images for the trans (been using jpeg). Again, thanks to everyone for the help. hdrider
No good deed goes unpunished ...
Hello, I am trying to use transparent planes and image files for some background stuff in Vue3 to cut down on polygon count. Problem: The planes aren't completely transparent. I'm getting a faint blue fringe. Anyone know the cure for this or is it just the nature of the beast? Thanks, hdrider
