Wed, Feb 26, 10:24 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Subject: No image file
Andarianedomon ( ) posted Mon, 19 January 2004 at 11:37 AM · edited Wed, 26 February 2025 at 7:35 PM
I have recently uninstalled Poser and pro pack and have started over (had lots of internal problems). NOW each time I install something I make sure it's there. If Not I go throught the task of finding out why and manually put everything where it should be. I have noticed one problem though with one particular item. it only has the rsr and cr2 and no image file, Whats the solution behind this little problem.
xantor ( ) posted Tue, 20 January 2004 at 1:40 AM
Maybe the rsr is an object rsr and not a picture one. If the rsr is much more than about 5 and a half k then it is probably an object rsr.
EnglishBob ( ) posted Tue, 20 January 2004 at 5:21 AM
I assume you don't mean image? CR2s can have embedded geometry; this type would need no external OBJ. If you look in the CR2 with a text editor that can handle large files, you normally see a line somewhere near the top which starts "figureResFile" and ends with the name of a .obj file. If you don't have such a line, you have embedded geometry and your item should work as is. If you do, then you need the obj file that's referred to. If the rsr file you have has the same root as the cr2, it will be the thumbnail; if it has the same root as the figureResFile obj, it's the geometry. I think Poser will accept a geometry rsr without the corresponding obj. If not, there's a utility for getting it back. However, if your CR2 calls for external geometry, and your rsr file isn't it, you're stuck. You would need to contact the item's maker and ask for a replacement obj.
Andarianedomon ( ) posted Tue, 20 January 2004 at 7:01 AM
Thnks I'll Chck it out
