Hi Thorrax, You probably replaced the figure with the clothing ... DO NOT ... double click on the library item. DO NOT ... apply library preset. With the figure in the studio ... DO ... select the item of clothing. DO ... click on the "double check" to ADD NEW (not replace) FIGURE. DO ... make sure the item of clothing is selected. DO ... the "Conform to" thingy. DO ... select the original figure. ... and you should be ... Good to go! cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Don't be embarrassed, the manual is wrong in this instance. This happens to everyone :) (Don't listen to the Doc!)
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Attached Link: http://homepage.ntlworld.com/vayne_xianah/conform.htm
Maybe this will help also, its based on Poser 4 propack, but it works the same in P5. I made this mini tut a while back. It comes in handy once in a while!! Good Luck -SimderZ- xXxAttached Link: http://www.daz3d.com
Thorrax - Victoria is available from DAZ. Link attached. Your credit card is about to go into meltdown. :)Coppula eam se non posit acceptera jocularum.
Awww, sorry Doc ;-) But we all know the best way to learn is from mistakes... ...so that means the people in here who know most, must have made the most mistakes, right? Well... I don't know the most by any means, but I reckon I'm a strong contender for "Most Mistakes Award" so maybe that theory doesn't hold up after all, heheh :-p
"you are terrifying
Shire
Hello Friends, I just received my Poser 5, installed it, and away I go. As I am reading and doing what the book (Reference Manual) says on page 68 (adding clothing), I opened the library, I selected the bikini top, and then I hit the apply Library Preset button. It says, the bikini top appears behind the figure, but, it actually appears infront of the figure because I dont see her I only see the top. Then it says to select the Figure>Conform to and select Figure one. Now, this I am assuming is at the bottom of the document window on the left? Well, I do that and when I open the Figure>Conform to the Conform to is not highligted for me to click? I hate to think the book is incorrect and it is only me. Thank you for help with add clothing everyone. Thorrax
