Funny I just came from the Amapi forum where I complained of a problem about using Amapi 7 for creating Morph targets.However the scaling technique which was also suggested for by Amapi tech support worked in Carrara 2 but for some reason with Amapi 7 it did not work for me...Anyone have any luck with Amapi 7???
that brings me one question... i once loaded a MT made for a collar, but applied it on the opposit collar.. guess that when i turned the dial it was a total mess.. but this made me wonder one thing: is there a way to "mirror" or invert a prop or a part/group of a figure with poser ? i am not talking about making simetrical morphs on same figure (MT mirror is a nice tool that does it), but for example you makes a morph target for one thing that often goes by two symetrrical inverted parts (collar, legs, arms), how can i use the MT i just made, in anyway, to make a "correct" duplicate for the opposite pat of the pair. Also if i have one prop, and want a mirrored/reversed version of it ? (exemple: hair patch props, such as in animedoll kit...) can it be done with poser and editing ? or do i need a more complex 3d modellign software ? (or any "free" simple one that could make this) ?
When you make an internal MT is it saved with that particular .pz3 file or that character file (in other words, everytime you use that character you have access to it but no other characters could have access to it)?
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
Yes.
. Try putting your figure in the Pose Room.
. Turn all IK chains OFF.
. Use the Joint Parameter (JP) Editor to "zero" the figure.
. Do a "Drop to Floor"
. Save your figure in the Figures Library (this creates a .cr2 file)
. Open the Walk Designer and select the "FIGURE TYPE" and load your figure. (the .cr2 file)
Yes.
. Just change the "scale" parameter.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
