Fri, Nov 29, 4:24 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: P5 Library custom UI question.
Tyger_purr ( ) posted Thu, 12 February 2004 at 12:45 PM · edited Fri, 29 November 2024 at 4:23 AM
Is there a way to change the text color, background color, text size, and or text font of the library? I have figured out how to change the folder colors, but cant find any of the above. I am afraid it may be in the utility.psd, but I cant open that in the version of Photoshop I have access to.
My Homepage - Free stuff and Galleries
Jackson ( ) posted Thu, 12 February 2004 at 3:30 PM
Not to my knowledge...changing background color was a feature they took out of p5. You never could change the text AFAIK. I've asked CL about it several times and they just ignore me. Oh, I understand that if you're on a Mac there may be a way; but I don't know what it is.
semidieu ( ) posted Fri, 13 February 2004 at 11:37 AM
Attached Link: http://www.keindesign.de/stefan/poser/tricks.html
You should find some tricks at this link... Simply edit the .xml files in the Runtime/UI
Tyger_purr ( ) posted Fri, 13 February 2004 at 12:02 PM
ok, that helps. but now i am left with the question... which widget is it?
Jackson ( ) posted Fri, 13 February 2004 at 12:30 PM
That's what I've been asking. I knew about the xml files but if you don't know what to change and what to change it to, it doesn't help.
semidieu ( ) posted Sat, 14 February 2004 at 4:41 AM
it depends on what you want to change... For example, for the background color, you must find: eGradientBackground Search the attribue "color" and change the value: 00000000 is black; 13879224 is the default color; 138 is blue; In fact, i don't really know how the colors works. It doesn't seem to be hexadecimal value... Hope it helps... You may find the other feature by serching for " font=" , ...
Tyger_purr ( ) posted Sat, 14 February 2004 at 4:40 PM
eGradientBackground does not control the library background. I appreciate the help, but it's not exactly what i am looking for.
