Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 11 2:52 am)
Attached Link: http://www.cocs.com/poser/reflectp5.htm
Try the link. It tells you exactly what you need to know.Coppula eam se non posit acceptera jocularum.
Were you using the draft settings when rendering? The shading rate in the draft settings is too big for sharp reflections, you need to lower it to 1 or 0.5 to get sharp reflections. In my experience, mirrors with less polygons work better than ones with many polygons (for example, the single sided square renders much better than the cloth plane - and uses less RAM too).
they are not blurry they reflect also the light.. plugin the reflection node under the Alternate diffuse set the alternate diffuse to white color and the reflection to the color you wish and everything will working fine.. use also Production rendering as stewer explain for sharp edges.
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
hey, I want to render a picture with a realistic reflection of the character i'm using. Something like a mirror would produce. I saw the reflection tutorial on this site, but it produces blurry images. What can i do, or where can i go to find this information??
