Fri, Nov 29, 11:52 AM CST
Subject: Can this be done...if so...HOW!?!?!
Melory ( ) posted Mon, 23 February 2004 at 8:54 PM · edited Fri, 29 November 2024 at 11:42 AM
Ok...here's what I'm trying to do. I want to make a MAT pose file that will put a transparency on an outfit without changing the texture of the outfit. So say I have a dress...i want to have a choice of either having the tummy on the dress invisible or not invisible...without changing the texture of the dress. Any way to do this? Any help would be appreciated.
Visit My Blog!
Crescent ( ) posted Mon, 23 February 2004 at 9:04 PM
I'm assuming you want a separate MAT file that only affects the transparency of the material. Say you want V3's abdomen to disappear:
version
number 4.01
figure
material SkinTorso
tMin 1
tMax 1
tExpo 0
transparencyMap ":Runtime:MyFolder:TransMap.jpg"
0 0
} (Substitute your transparency map for ":Runtime:MyFOlder:Transmap.jpg") If you want the entire abdomen to disappear, you can even take out the transparencyMap line and the double 0's on the next line. Grain of salt: I'm in the middle of a project, so I can't test this to make sure I have all the }'s in place. It should be right, but it may need a touch of tweaking. Cheers!
Melory ( ) posted Mon, 23 February 2004 at 9:08 PM
oh im such a putz...i had all that and it didn't work...turns out I forgot the tMin 1 tMax 1 tExpo 0 part...how embarassing :( Thanks for the help cresent!
Visit My Blog!
Mec4D ( ) posted Mon, 23 February 2004 at 9:18 PM
you need to create separate Mat files.. then edit it manually using your text editor.. you can pick up the exact settings from the cr2 files.. something like this.. this will set up the tummy material to 100% transparent without to affect the textures.. ---------------------start_code---------------------------- { version { number 4.00 } figure { material Tummy { KdColor 0.0588235 0.0588235 0.0588235 1 KaColor 0 0 0 1 KsColor 0.0588235 0.0588235 0.0588235 1 TextureColor 1 1 1 1 NsExponent 30 tMin 1 tMax 1 tExpo 0.6 } } } ------------------end_code------------------------------ that is simple transparent Mat files that need to be save as a pz2 .......... Cath
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
Mec4D ( ) posted Mon, 23 February 2004 at 9:29 PM
Ops.. was to late with reply LOL :)
Melory ( ) posted Mon, 23 February 2004 at 9:42 PM
well i appreciate the help anyway :)
Visit My Blog!
