Sat, Nov 30, 5:10 PM CST
Subject: P.A.E. incompatibility
gsimmons ( ) posted Mon, 18 September 2000 at 11:02 PM ยท edited Sat, 30 November 2024 at 4:33 PM
gsimmons here! I posted a message earlier on about my problems with the P.A.E. program and my inability to make it recognize my bvh files. MASA (the creator of the program)then helped me figure out the problem. I never downloaded the Poser Patch therefore it didn't work. The reason I post this message is because MASA would like to know if anyone else is having or had the same problem. I believe the P.A.E. system is incredible and everyone with Poser should at least try it out. Thanks!!!
JeffH ( ) posted Tue, 19 September 2000 at 1:04 AM
Yes the program is cool, but isn't it specific to just one model? Nene-Lite? It would be great if it could be adapted to any model. -JH.
f91 ( ) posted Tue, 19 September 2000 at 2:31 AM
JeffH, P.A.E. it will work on any model as long they have P.A.E. morphs. You can creat your own P.A.E morphs. Something likes Paeupx, Paedownx, Paeleftx, and Paerightx. Just make sure the internal name is Pae...x. Gerry ;)
Chris ( ) posted Tue, 19 September 2000 at 2:49 AM
Jeff, just copy the PAE morphs from the Nene character to your own character. I have done that and it works fine. Chris
"It Is Useless To Resist!" - Darth Vader
JeffH ( ) posted Tue, 19 September 2000 at 8:01 AM
Okay there's where I went wrong. My morphs didn't have the x on the end. Thanks, -JH.
Nebula ( ) posted Tue, 19 September 2000 at 9:19 AM
You mean these PAE morphs can be copied to any character as long as the naming convention is kept and it will work? Can I make my own morphs and name them properly and it work?
Grammer ( ) posted Wed, 20 September 2000 at 2:34 AM
This is the case. PAE also works on clothing via EMC- morphs - check out MASAs site
MASA ( ) posted Thu, 21 September 2000 at 12:46 PM
Thank you for the post. P.A.E Next version solve about the incompatibility problem. I feel encouraged as your help. Nebula, If MT name is same ,You can use new MT. P.A.E algorism only use BVH. Thank you again. MASA
