Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 22 9:03 am)
$14.99! That's not bad at all!
What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
I note that the .obj for this model is not called from the geometries folder, but from the character folder. I discovered this by looking at the .cr2 when the obj could not initially be found by poser. It's referenced at: Runtime:libraries:character:Cubed Dolphin:Cubed Dolphin.obj. When placed there, it works fine. Was there a rationale for this placement? I manually install everything and initially put the .obj and the folder it was unzipped to (DolphinCubed), into the Geometries folder of my main runtime.
mmm! hadn't spotted that Sandoppe_ ProPack does that automatically when you create a library figure. Most of the brokerage sites including DAZ and Rendo require brokers to 'undo' all that (which is a faff but not difficult) It might be something for 'cubed' to bear in mind. I too had to 'find' the obj when I first loaded it in to a scene.
Just out of curiousity Noggin: In subsequent loads, does P5 ask you to find it again? I would guess it does as P5 seems to read the .cr2 and will not search further for the .obj if it can't find it in the location referenced. If P5 had searched the geometries folder, it would have found the file without asking. It loads pretty quickly when placed in the character folder.
It will cause problems in P4. With cr2's there are two lines that have the geometry location which should be changed.
E-mail
| Renderosity
Store | RDNA
Store
Yup! I found the two lines. I changed them to a new path/folder in the geometries folder in my main runtime. The only other files involved are the MAT pose files and they just reference the textures. Seems to work fine and loads a bit faster than it did in the character folder. P5 is not quite as fussy as I guess P4 is about the .obj files. It will let you search for a missing .obj and will even go "lay down by it's dish", if you can't find it!:) P5 gets a lot more goofy about textures it can't find than it does .obj files.
Really nice, Chris! Now, I wonder if you'll get around to offering us a horse that has slightly better knees than a certain other new horsie... Or perhaps a wolf with a grin Or maybe even a decent snake (other than the esteemed noggin python, that is)...
Attached Link: http://www.cubed.ie/cgi-bin/db_detail.pl?ProductID=10332-18&Master=10332-18&ProductType=Poser%205
Cubed have released the new Bottlenose Dolphin!This fine mammal has been built from the ground up with animation in mind. It comes complete with photorealistic textures and MAT files for an underwater look or a wet look above the water.
There are separate version for Poser 4, 5 and Pro Pack. The Poser 5 version makes extensive use of the Firefly shaders, as we did with the babies.
We have kept the price down to a respectable 14.99 Euro. Animation and poses will be sold separately.
