Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
I've used cameras with a field of view of 1 degree to get images with no vanishing points.
I just used the 200mm camera. As a side-note, the entire image all 3 map/models- were built as seperate models by me and co-worker James Hendricks over a two week period. When it came time to render, I thought that I would render them as seperate files and composite the results but after the third try I gave up because the perspectives never matched up. So I brought all 3 models into one file and rendered everything at once. We just got new computers last month (dual 2-ghz G5, 3 gigs of ram, fastest Radeon card they make for the Mac) so I figure, no problem. Wrong. This file brought my machine to it's knees. Moving objects around became a test of patience but rendering went okay.
I think the second CPU only helps out with rendering. Not with scene/model assembly.
For city blocks, I move my scenes around using binding-box mode. Not textured or rendered (or even line) mode.
