Forum Moderators: RedPhantom
Got that. I ought to have said that I should be working, and don't have access to Poser until tonight (I'm on GMT+1). However I successfully opened both OBJ files in Anim8or - test1 is just a cloud of vertices of course, but test2 looks like an actual head. On comparing the files, their v lines are identical as far as I can tell. Assuming you don't get a 'wrong number of vertices' error, it /should/ work... What procedure are you using to apply the morph?
Boy, is that helpful. Not. And the chances of CL going back to an old version of Poser to fix any bugs is minuscule. They can't even debug Poser 5. It beats me how they can break a feature like that, but it's not the first time that code that was fixed in one version became un-fixed in the next. :-( That seriously reduces our options for distributing morphs, since an OBJ with facet information left in will be in breach of copyright. The vertex-only form is generally accepted as being safe to distribute, since it's too much trouble to join all the dots together and make your own Vicki. :-) Maybe this explains why I've seen people sharing morphs as a CR2 'carrier', with which you have to use Morph Manager to copy the deltas into your own character CR2. Where did you find out about this, by the way?
WOW it's work on mac now !!! ** Tutorial Morph Squishing 102 for macintosh ** as Morph Squishing 102 tutorial BUT .. for mac user is need add this special line "f" to end of "v" lines example: v -0.00827163 0.635433 0.041891 v -0.00820857 0.63581 0.0426039 v -0.0121407 0.635551 0.0394929 f 1/1 2/2 3/3 4/4 many thx EnglishBob for have fix this problem :-D
I have remove all lines as in tutorial: vn lines (Normals) vt lines (UV mapping lines) g lines (Grouping Data) usemtl lines (Material Data) mtlib lines (Material Library pointer lines) f lines (Face Data) and i have save only "v" lines but when i try to load my morph i read this message: Couldn't read the geometry file But if i delete all lines but don't delete the "v" lines AND "f" lines, the morph is ok .... ???!! where is my error ? thx for feedback ;-) Andygraph
