"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Mike 2 and the original Stephanie can also (more or less) share textures between each other.
The only thing is that the girls have a couple parts with different names (EyeLashes as opposed to Eyelashes, or the other way around, and the same thing with EyeBrows versus Eyebrows), so you usually have to manually apply the texture and trans MAP to the eyebrows and eyelashes if you're using a MAT pose. Took me ages to work that one out! ;-) bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
Hey thanks that worked out great! I also discovered that just about any PT/PS bodytex is interchangable, as well as V2. Thing is, stuff doesn't come out exactly perfect -- nurples, for example, usually come out white or a different color than on the original mat -- but other than that, the mats work fine. Any idea what causes that color change, btw?
there's some inconsistency in material zone names, eyeball vs eyeballs, nipple vs nipples. Its silly but poser is a stickler for exact name matching. The solution? make a new mat, or edit the mat to add the variant name. Or change it manually if editing mats scares you :) The Real solution? the maker making the thing to match 100% ahem which would be DAZ in this case
I think I read a post here a while back where somebody said the Victoria body textures are compatible with Mil Girls. I searched but couldn't find the thread. Anyhow, is this true? And if anyone has tried this, how well does it work? I've tried swapping out textures between figures before with little success. I also wonder if this is true, if perhaps the Mike textures are compatible with mil boys?
