Fri, Nov 29, 10:59 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Off screen
D0GG0D ( ) posted Fri, 13 October 2000 at 10:03 AM · edited Mon, 25 November 2024 at 9:38 PM
I'm a new user and keep having a problem with tools being partially or totally off screen. How do I recover them when I can't click on thier drag section at the top ?
Kevin ( ) posted Fri, 13 October 2000 at 11:30 PM
Reset to factory defaults.
bloodsong ( ) posted Sat, 14 October 2000 at 10:18 AM
heyas; and after ya get things set up the way you like 'em, click on a UI DOT to save 'em. if the ui dots are on screen when everything else is falling off, you can click on it to get things organized again. plus, if your ui starts up messed up every time... there's a fix for this... i posted it on the poser forum under... well, search for wayward ui, you should find it. :)
D0GG0D ( ) posted Sat, 14 October 2000 at 7:38 PM
Thanks
