Fri, Nov 29, 10:11 AM CST
Subject: targetGeom VS valueParm
iamonk ( ) posted Sat, 17 July 2004 at 8:54 AM · edited Mon, 25 November 2024 at 10:36 PM
So what's the major difference if both seem to get the job done?
lesbentley ( ) posted Sat, 17 July 2004 at 10:28 AM
A targetGeom channel is designed to work as morph holder, that is it can contain deltas (the elements that comprise a morph target). A valueParm channel is usually used as a master channel in an ERC (Enhanced Remote Controle) relationship. A valueParm channel can't contain deltas, therefore it can't work as a morph channel. Most channel types can be used as master (or slave) channels in an ERC relationship, however the trackingScale for most channels is hard coded, the trackingScale for a valueParm channel can be set to any value desired, this makes it the best choice for a master channel in some circumstances.
iamonk ( ) posted Sat, 17 July 2004 at 10:54 AM
That's good to know. I'm using a .cr2 with a readscript to load an existing .cr2 and inject channels. I've managed to inject the slaves in the body parts, and the masters in the BODY. I got the initial value of 1 of the master to work by using key kd 0 1, originally it was kd 10 and that didn't work. I want to have the slaves hidden, using hidden 1 doesn't cut it. Is there something else to set as in the case of the initial value?
iamonk ( ) posted Sat, 17 July 2004 at 12:49 PM
Sorry, that should "k" not "kd". It was late last night when I toyed with it, early this morning when I posted. I searched the Poser Technical forum here about hiding the dials. Is there really no way of keeping them hidden after reload?
lesbentley ( ) posted Sat, 17 July 2004 at 3:08 PM
Ok first the "keys" block. In a static pose you have one "k" line that contains two numbers, the first number is the frame number and will always be zero in a static pose. The second number is the paramiter value, essentialy this is the number that appears on the dial in the Poser interface, except that for a scale channel "1" on the "k" line will be represented by "100%" on the dial. Back to that first number after the "k", thats the frame number. If you have a look inside an annimation pose, like "sexy walk.pz2", in each channel you will see 30 k lines, starting with "k 0" and ending with "k 29" these lines relate to freme numbers in an animation. So if the channel is a scale channel (for example), then; k 0 1 k 1 1.5 k 2 0.5 reads as; in frame 0 set the scale to 100%, in frame 1 set the scale to 150%, 2 set the scale to 50%
lesbentley ( ) posted Sat, 17 July 2004 at 3:29 PM
Hiding the channels, I have never tried this in conjunction with readScript, I suspect it would work the same as with a straight delta injection pose, that is to say the "hidden 1" line should go directly under the closing brace for the delta section. I have never found much use for readScript (don't have V3), so can't give you the the exact syntax, I think it would depend on how you impliment the readScript. If you posted a section of your code I could probably show you where to slot it in.
iamonk ( ) posted Sat, 17 July 2004 at 3:58 PM · edited Sat, 17 July 2004 at 4:02 PM
I read your thread in Poser Technical about the hidden line under the deltas, that works.
I've made a few morphs that I'd like to distribute.
Injection into the original .cr2 seems to be the best way to do it.
With the readscript, I call the original .cr2, inject my morphs and extra channels. Since since several body parts are affected by the morphs, I'm injecting the ERC and hiding the body part dials. Control is through the BODY. I'm also setting it up to keep my settings if you restore the figure. I thought I might have issues with the dials reappearing if the character is saved back to the library and opened again, but I'm realizing that there is no need to save the character, just a pose.
Anyway, the reason for the readscript means I don't distribute a bulky .cr2, just the changes. They can keep the original morphs without having to transfer them over to my character.
If they have a modified character with additional morphs, they can just edit my file to point to that one. It's only one line in the beginning of the file.
Anywho, I'm pretty new to this sort of thing, but I got it doing what I want it to now.
Not that I truly understand much of it, but it works.
Here's what I got, the body part dials are hidden as well.
readScript ":Runtime:Libraries:character::.cr2"
actor BODY:1
channels
targetGeom X
name X
initValue 1
hidden 1
forceLimits 4
min -100000
max 100000
trackingScale 0.02
keys
static 0
k 0 1
interpStyleLocked 0
indexes 0
numbDeltas 0
deltas
hidden 1
This is a snip of the file I tried with a targetGeom instead of the valueParm, there aren't any deltas here, and there's probably more stuff here I don't need.
But it works.
Message edited on: 07/17/2004 16:02
lesbentley ( ) posted Sun, 18 July 2004 at 9:10 AM
Glad to hear you got it working. The second "hidden 1" line seems to be in the right place, but I don't think it's necessary in this instance. It seems to be reading the deltas that turns visibility back on for the dial, when there are no deltas I think the "hidden 1" statement can just go in the normal place.
"there's probably more stuff here I don't need". As you are just using this as a master channel you could leave out the bits marked in red, these are all default values and Poser will add them back in when the file is loaded, but you can save a tiny bit of disk space by choping them out.
targetGeom X
name X
initValue 1
hidden 1
forceLimits 4
min -100000
max 100000
trackingScale 0.02
keys
static 0
k 0 1
interpStyleLocked 0
indexes 0
numbDeltas 0
deltas
There again, if it ain't broke why fix it?
iamonk ( ) posted Sun, 18 July 2004 at 11:10 AM
Thanks, it's good to get rid of bulk.
