Thu, Feb 27, 5:08 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
Subject: Magnets & Grouping Tool
Eowyn ( ) posted Thu, 22 July 2004 at 7:27 AM ยท edited Sat, 22 February 2025 at 2:47 AM
Hiya! I know this has been asked before but I couldn't find the thread anymore... I'm trying to create head morphs using magnets but I don't want the magnets to affect the inner parts of the figure's mouth (teeth, tongue, gums...). I remember there was a thread where someone explained how that could be prevented using the grouping tool.. but I can't remember anymore how it was supposed to be done. Help, anyone? -Eowyn
geep ( ) posted Thu, 22 July 2004 at 9:28 AM
Hi E, Use the Grouping Tool to make a separate group from the head that does not include the inner parts. Next, select the Head and Create Magnet. Now, under the Mag ZONE Properties, you can select the (new) "group" that you just made, and only it will be affected by the magnet. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Eowyn ( ) posted Thu, 22 July 2004 at 11:39 AM
Woohoo, thanks :D I'll see if I can figure it out :)
pookah69 ( ) posted Thu, 22 July 2004 at 11:52 AM
Just be aware that this function does not work on the Mac version of Poser 5. I have already contacted Curious Labs, they say they are working on a fix for the next SR.
Eowyn ( ) posted Thu, 22 July 2004 at 12:01 PM
I'm on P4 & Pro Pack so I shouldn't have problems :)
shadownet ( ) posted Sat, 24 July 2004 at 7:36 AM
Eowyn, be aware that if you make any changes to your mesh using the grouping tool in Pro Pack, than save the figure to the Library, PP will create a new object for the figure and place it in the same folder where you save. For example, say you have V3 in your scene and you group the face mesh as you describe. You decide to save this modified figure to the Library as Jane.cr2. PP will create a new object called Jane.obj in that folder, and will set the call path for the geometry to look for this object instead of the usual blMilwoman object in the geometry folder. This can be both good and frustrating at times, but so long as you know that it happens - you can at least deal with it. :O)
Eowyn ( ) posted Sat, 24 July 2004 at 10:41 AM
Oh, I had no idea it would do that! Thanks for letting me know! :)
Xena ( ) posted Sat, 24 July 2004 at 8:08 PM
If you group the figure, use your magnet and spawn the morph, save the character to the library as a new character (as Shadownet says above), you can then go and use MM4 and transfer the morphs from the new character to the original character and they'll work no problem.
