Hello Little Dragon :) I forgot to mention in my post that I tried ctrl+G without success. How does one pull up the Hierarchy Editor? The Set Parent button is also greyed out on the properties for the GROUND. (PS in a fit of panic I made a blank scene, enabled ground, applied my ground texture, then saved as PZ3, opened my groundless scene and did a File>Import poser document/item and restored my ground. This is good enough to render but I wanna restore my original ground in the groundless pz3 please) Thank you :) Logan
cheers,
dr geep ... :o]
edited 10/5/2019
Hello lesbently :) This is exactly what I considered doing if my gambit of saving a ground only scene as a .pz3 then doing the File>Import Poser doc/item failed. I never did try it when the import did the trick, but based on the success of the .pz3 method Im positive this would have worked :) I love hearing that im starting to think as the people around here do!!! Logan
Hello, I went to hit ctrl+R and accidently hit ctrl+E and now my ground plane is completly invisible and when I go to its properties, the visible option is greyed out and I cant re-enable it. Can anyone help? thank you, Logan
