Thu, Feb 27, 4:15 AM CST
Subject: Bryce ate my UV
xenic101 ( ) posted Thu, 29 July 2004 at 10:44 PM · edited Sun, 01 December 2024 at 11:52 AM
I've imported hundreds if not billions of naked vickies into bryce. Suddenly, the body texture doesn't stick! Hopeing its just a fluke, I cleaned it up in post, got a little post work to do still. I'm going to try TwistedBolt's suggestion. Gotta go outside to smoke, then I'll finish post, and upload.
xenic101 ( ) posted Thu, 29 July 2004 at 11:14 PM · edited Thu, 29 July 2004 at 11:16 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=728465
Dear me! What's happened to my priorities. (violence & nudity)
Message edited on: 07/29/2004 23:16
tjohn ( ) posted Thu, 29 July 2004 at 11:55 PM
What mapping type is set for the body texture? This doesn't look like parametric.
xenic101 ( ) posted Fri, 30 July 2004 at 12:16 AM
Yes it's parametric. for the final pic I changed it to parametric scaled, didn't fix it of course but did give her a more roughed up look. Texture worked fine for the head, hair, and clothes, just the body tex got messed up. I had thought that this happened around untitled12.br5 or so, but looking back, it's wrong as soon as I imported the figure. I'm pretty sure it's a Poser to Bryce fluke. Somewhere the UV data got lost. Couldn't tell in the test renders, thought it was something else. Could reload the obj re-export the obj from poser to find out if it was poser or bryce that dropped the ball, but as long as it doesn't become a habit.... Yeah, I turned off the other channels in the material, didn't help.
draculaz ( ) posted Fri, 30 July 2004 at 3:24 AM
either bad mapping or just bryce being icky. make a new scene, import the whole thing again and do it over, and it might work. then bring it back into the original.
dan whiteside ( ) posted Fri, 30 July 2004 at 7:32 AM
What I'm thinking is that the body image texture component has a non-zero frequency value. If the import had no UV mapping at all, parametric mode would yield a solid color object. If it's not this ya got me stumped! HTH; Dan
xenic101 ( ) posted Fri, 30 July 2004 at 10:15 PM
Golly jee, I must have bumped it. The scale for the texture map was set at 51%. Dan wins!
