Fri, Nov 29, 1:51 AM CST
Subject: Divx continued
3dz ( ) posted Tue, 03 August 2004 at 11:57 AM · edited Mon, 25 November 2024 at 12:27 PM
I hope you found it all right. I am beginning to think my problem are not with the Divx codec. As you pointed out, yours seems to be working fine. Normally on step 8, I clicked on OK. This time I clicked on configure, and okayed on the defaults. I still come up with an error, but now I think it's a memory problem. I checked in the system resources and the memory showed 148,000 kB I have 1024 MB. So now I got to figure out how to fix it. I was thinking about pulling out one strip of memory at a time, and then replace it. Letting new hardware find the memory and recalculate. What you think?
Message edited on: 08/03/2004 12:05
3dz ( ) posted Tue, 03 August 2004 at 12:00 PM
Here is the error I keep getting.
raven ( ) posted Tue, 03 August 2004 at 12:04 PM · edited Tue, 03 August 2004 at 12:16 PM
To have DivX encode the output size must be certain dimensions. I think it is that the width must be divisible by 4 and the height divisible by 2 (or the other way around). Not having those dimensions will stop DivX from working, giving that error message, I found that out in Poser.
Message edited on: 08/03/2004 12:16
3dz ( ) posted Tue, 03 August 2004 at 6:08 PM
I checked my other computer (the one with Poser on it), and the settings were the same. I'm really beginning to believe I'm having memory problems. That would explain the long render times. If I'm not mistaking, 1000 kilobytes make a MB. If this is the case then, I'm only using a little over 10 percent of my RAM. The default setting in Divx on my other computer seems to work fine. Considering that my computer is showing 148,000 kilobytes of RAM, I would think that is my problem. It's funny that I did not catch this earlier. When I seen the error message, I thought I should check. Hopefully new hardware will find the RAM and recalculate.
Vile ( ) posted Tue, 03 August 2004 at 9:49 PM
listen carefully cause raven is right! Change your document size to 320x240 or 640x480 or 800x600 or 1024x768 etc... then try it again.
AgentSmith ( ) posted Wed, 04 August 2004 at 4:06 AM · edited Wed, 04 August 2004 at 4:16 AM
Attached Link: Divx in bryce screenshot
What are your frame dimensions?
From your measuring your screenshot it looks to be 540 x 405?
Yes, dimensions should be divisable by 4 and optimally by 16.
I strongly suggest you update from your 5.0.2, and get the newest divx codec, version 5.2
AgentSmith
Message edited on: 08/04/2004 04:12
Message edited on: 08/04/2004 04:16
Innovator ( ) posted Wed, 04 August 2004 at 4:42 AM
or...render out to jpgs or tifs or tgas sequence (or whatever Bryce has available for sequence files) and download a trial copy of adobe after effects or premiere and import them. Then you can export as any movie format with any codec available. or do wut the others said and check your resolution :-)
3dz ( ) posted Wed, 04 August 2004 at 9:01 AM · edited Wed, 04 August 2004 at 9:03 AM
I'm glad everybody persisted with the document size. I rechecked the memory and, I missed a 0. The reading was 1,048,000 which is correct. I then changed the document size, and it worked. "You learn something new everyday" thank you to all, I am a happy Brycer once again. I can now render my Bryce animation in Divx. Once again thank you.
Message edited on: 08/04/2004 09:03
AgentSmith ( ) posted Thu, 05 August 2004 at 5:03 AM
Very cool, glad to ear ya found the monkey wrench in the machinery! ;o) AS
