O.K., on further investigation: The "applying a non-translated pose" to fix the problem doesn't work, unless you start out with a edited CR2 file. Poser 4.0.4 does save the transition, I was mislead because they don't work unless the CR2 file has been edited (the Vickie CR2 are in effect "locked" into the transitions. I've made a "corrector" pose file that will fix the corrected Vickie figure back after applying a "uncorrected" pose - it has been hand edited to only effect the transitions (which are otherwise not part of any pose, anyway. I'll put a corrected CR2 for Vickie and the "corrector" pose file in Freestuff this weekend. The deal is to fix the offset finger problem Vickie has in the latest version of Poser you have to use the new CR2, then if you use any Vickie pose file that wasn't made from a "corrected" Vickie you will have to apply the "corrector" pose. Are we even more confused yet?
