Sat, Nov 23, 3:44 PM CST
Subject: Michale 3 Body Suit VS Others
Macsen ( ) posted Fri, 13 August 2004 at 8:25 PM ยท edited Sat, 23 November 2024 at 1:04 PM
Hi. I'm a bug fan of Michael (since he looks more mature out-of-the-box than David and more aestethic than Freak) but... I've seen David's Bodysuit has a lot of transparency options for the suite, and the Freak's too... Michaels is too conventional for that in comparision... Does anybody know if DAZ is working on an update for it or something? I want to do some tricks that requires transparency bitmaps for it instead of just turning it off in the maps... Hope I explained well... Rick
pdxjims ( ) posted Sat, 14 August 2004 at 12:31 AM
The David Ultra suit has 24 mapping zomes, while the M3 body suit has only 12. The Freak's has the same mapping zones as the David version. The M3 suit has only a wrinkle morph in addition to the M3 body morphs, while the David version has 22 different morphs in addition to the David FBMs. Of course M3 has more body morphs than David, so the total number of morphs is about the same. The David version comes with two seperate UV mappings, one is very similar to the David mesh itself. The M3 version has only 1. And it doesn't match either of the David ones, so you can't use the same textures. I'd like to see the M3 version done the way the David version is: mapping zomes, morphs, different UV versions. I don't understand why they haven't updates the M3 version, since they have the Freak's. The David and M3 suits are the same price though. The Freak's is $5 less.
Macsen ( ) posted Sat, 14 August 2004 at 10:03 AM
Exactly my point... even V3's has less features than even "The Girls". The only reason I found is that V3's and M3's are Originals while the others are Brokered... but that should not stop them from updating them. Even if M3 (and the boys) get less attention at the spotlight, V3's could benefit from that too... Guess we'll just have to wait and let time decide... Rick
FyreSpiryt ( ) posted Sat, 14 August 2004 at 9:29 PM
The problem here is that 3DWizard made David and Freak's bodysuits, while I think Michael's was made internally at DAZ. It was certainly made by someone else. 3DWizard is just much much better at it.
Macsen ( ) posted Sun, 15 August 2004 at 1:32 PM
Let's hope DAZ tries to give the old ones to the 3DWizard for a needed update... I'll just sit and wait... Rick
