Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
There was a post here last week about this subject. Long and the short is, don't do it, it breaks Poser.
Yep, Content Parasite is safe to remove, the others aren't. Apologies if I wasn't clear in my above post.
Attached Link: http://www.poserpros.com/forums/viewtopic.php?t=16569
here's the link to the thread that tells how to remove Content Paradise...Actually, the Posr 5 interface and tools should be almost completely cusomizable... the problem is that you have to be able to read and understand the big xml file that controls it all, and have a good clue as to how everything effects everything else. Sooner or later, someone will figure it all out, and maybe we can have some skins for poser, but it will take a much smarter person than me. ;) The reason Content Paradise is safest and easiest to remove is that it doesn't interact with the rest of the application. Taking out the face room means removing elements that it will share with the hair room or the materials room, for instance. So, yes, that will probably break Poser.
OK, now that you've got it right, save a copy of the edited version onto a floppy so that if you ever have to do a reinstall, you can just copy it into the ui folder and not have to go thru all that again.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Just got P5 and have no use at all for the Content Parasite room. I read a thread here a couple weeks ago on deleting P5 rooms but can't find it. I've also searched P5's docs but no luck. This newbie needs a step-by-step, if anyone can help. I'm on a Mac, with Poser 5 SR4. Thanks!
