Sat, Nov 30, 9:30 AM CST
Subject: F16
dutchman ( ) posted Wed, 01 September 2004 at 8:55 PM ยท edited Sat, 30 November 2024 at 9:30 AM
Attached Link: http://www.dutchman3d.com
Go to Download page.
Jcleaver ( ) posted Wed, 01 September 2004 at 9:11 PM
Thank you very, very much!!!! I have been looking for one of these!
Jcleaver ( ) posted Wed, 01 September 2004 at 9:23 PM
BTW -- the zip file is corrupted. I tried twice, with same result.
dutchman ( ) posted Wed, 01 September 2004 at 10:30 PM
Hmmmmm. I downloaded the file and everything unzipped okay. Anybody else have any trouble with the zip file?
XENOPHONZ ( ) posted Wed, 01 September 2004 at 10:42 PM
mateo_sancarlos ( ) posted Wed, 01 September 2004 at 10:43 PM
Dutch, the site didn't load for me (Explorer and Netscape).
dutchman ( ) posted Wed, 01 September 2004 at 10:51 PM
This is very strange. I believe the lousy plane must have bombed my site. On the serious side though, I am baffled you had trouble getting into the site. I just went there and everything was okay. I have no password or cookies to access the site. Let me know if you figure the problem.
numanoid ( ) posted Wed, 01 September 2004 at 11:15 PM
Some people using Windows XP cannot view applets, and that may be causing some problems. They need to install the java pack from Sun. (for some reason Microsoft disabled applets in XP and the new Internet Explorer 6)
dutchman ( ) posted Wed, 01 September 2004 at 11:21 PM
Thanks numanoid; You are probably right about this.
igohigh ( ) posted Thu, 02 September 2004 at 12:17 AM
Attached Link: http://www.java.com/en/index.jsp
Microsoft anounced some time back that the Virtual Machine (what allowed Windoze to view java) is no longer supported. It has to do with a falling out between Sun MicorSystems and Microsoft. The code never actually belonged to MS. In order for Windows OS to continue to utilize Java based applications you must switch to the Sun System's 'Java Console'. Read details here: http://www.microsoft.com/mscorp/java/ and here: http://www.microsoft.com/presspass/press/2004/apr04/04-02SunAgreementPR.asp Get Java here (note: Microsoft will NOT support any issues that may arise and Sun Systems is responsable for All security issues): http://www.java.com/en/index.jsp
aeilkema ( ) posted Thu, 02 September 2004 at 2:16 AM
I can open the zip file, extract most of the files except the texture.bmp, it's corrupted. In WinZip I do get this: Extracting texture.bmp Error: unexpected end of file encountered Error: invalid compressed data to inflate Tried downloading the zip files a couple of times, but with the same result eacht time.
Food for thought.....
Roy G ( ) posted Thu, 02 September 2004 at 5:07 AM
I had the same problem as aeilkema.
I could not get the texture.bmp to extract.
pisaacs ( ) posted Thu, 02 September 2004 at 6:13 AM
Ditto, bad texture.bmp.
MungoPark ( ) posted Thu, 02 September 2004 at 6:50 AM
No problems on the MAC though......
compiler ( ) posted Thu, 02 September 2004 at 7:55 AM
Same here : some files got corrupted. Thanks anyway for your generosity. I knew I had a reason to download that SAM7 missile model...
hemi426 ( ) posted Thu, 02 September 2004 at 1:43 PM
BTW: The plane on the first render is an F15, not an F16. I also couldn't open the zip-File :-(
dallas40m ( ) posted Thu, 02 September 2004 at 2:11 PM
File corrupted wont open here either.
Warmest Regards,
Dallas
LilWolff ( ) posted Thu, 02 September 2004 at 4:00 PM
Just downloaded it and it opened fine for me. The only thing I had to do was use edit pad to change the texture.bmp that the pp2 called for - to the texture.jpg that is included in the zip file. You might want to do that before you load it into poser and get the can't find message. Nice F16, thank you for sharing it. :-)
1010 ( ) posted Thu, 02 September 2004 at 4:04 PM
I just downloaded it and everything opened fine for me. I have W98 se. May I ask a dumb ??? Do I put the files in my props library or figure library? Thank you!!!!!!!!!!! I love it, zoommmmmmmmmmmm
http://creationsbydawn.net
LilWolff ( ) posted Thu, 02 September 2004 at 4:12 PM
pp2 is a prop. I put the textures in with the F16 pp2. Am sometimes very lazy. ;-)
1010 ( ) posted Thu, 02 September 2004 at 4:13 PM
Thanks for the answer, I love jets.....
Penguinisto ( ) posted Fri, 03 September 2004 at 10:55 AM ยท edited Fri, 03 September 2004 at 10:58 AM
Much thanks - As someone who once tore these jets apart in RL, I'd like to beat up on the texture a bit... I'll post the results if I can get time to actually do it.
Also, I'll see if I can't set up some smart props to tack noto it for the missing parts (wingtip rails, upper UHF antenna, etc.) as well as some optional parts (external fuel tanks, EW pods, etc.)
/P
Message edited on: 09/03/2004 10:58
