Sun, Dec 1, 1:26 PM CST
Subject: +++ DG#046 +++ The Poser Arch +++ REPOST +++ Page 1 ...
geep ( ) posted Thu, 02 September 2004 at 11:32 AM · edited Sun, 01 December 2024 at 9:07 AM
cheers,
dr geep ... :o]
edited 10/5/2019
Replicant ( ) posted Thu, 02 September 2004 at 11:49 AM
Curses! This is not about morphing eyebrows! Guess I'll learn something even more useful instead. :o)
Expert in computer code including, but not limited to, BTW; IIRC; IMHO; LMAO; BRB; OIC; ROFL; TTYL. Black belt in Google-fu.
tpriest ( ) posted Thu, 02 September 2004 at 1:42 PM
Got my seat. Early for a change...
Porthos ( ) posted Thu, 02 September 2004 at 1:51 PM
Yay, front row!!! 8D
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
geep ( ) posted Thu, 02 September 2004 at 10:35 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 02 September 2004 at 10:36 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 02 September 2004 at 10:37 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 02 September 2004 at 10:38 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 02 September 2004 at 10:40 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 02 September 2004 at 10:41 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 02 September 2004 at 10:43 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 10:54 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 10:55 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 10:56 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 10:58 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:00 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:01 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:03 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:04 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:05 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:07 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:09 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 03 September 2004 at 11:11 AM
cheers,
dr geep ... :o]
edited 10/5/2019
AntoniaTiger ( ) posted Sat, 04 September 2004 at 3:49 AM
Isn't there another way to make the second half-arch? Get the first made, and then use the grouping tool to make a copy, rotate and translate the copy, and weld. Or does that lead to problems with the origin?
geep ( ) posted Sat, 04 September 2004 at 6:05 AM
Hi Antonia, Ah, now *that* is a very good question and the answer is ... Um, now where did I put that answer ... (*shuffles numerous piles of papers around on his virtual & pepetually messy and cluttered desk*) Well, er, let's see ... in order to make what would essentially be a mirror image of something we would need an exact center line upon which we could "split" the object. If you will look closely at Page 12, on the left hand side where it says, "DO NOT INCLUDE THIS PIECE!," there is (are) no vertex(es) that are in the (exact) center. Therefore, we cannot "mirror" the object and still maintain a smooth arc. So, the problem lies not with the origin, per se, but with the alignment of the two halves. Ok? cheers, dr geep ;=] P.S. You cannot "weld" vertices inside of Poser. You can only "weld" identical (location) vertices when you import an object.
cheers,
dr geep ... :o]
edited 10/5/2019
