The stuff on the cheek looks like a problem with the geometry, like perhaps the vertices aren't welded where they should be. With a high resolution render problems like that will be exposed. It doesn't show on the low resolution because your sampling isn't high enough to expose those tiny flaws. The hair thing looks almost light a GI artifact, perhaps kicking up the quality, turning of interpolation, or kicking up the # of photons on the larger renders would help fix that. Nice textures BTW. Good luck, Eric Winemiller Digital Carvers Guild 3D plug-ins for Carrara http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
Did you weld those spots on the cheek? Eric Winemiller Digital Carvers Guild 3D plug-ins for Carrara http://digitalcarversguild.com
Eric Winemiller
plug-ins
Congratulations, you've found something strange! All of the ultra close-ups I've done have never exhibited this issue. Eovia tech has always been pretty responsive - I'd suggest letting them know your issue and see what they say. It still looks like a geometry issue but if you've welded the point on the figure, I don't know what else to suggest. Please post back when/if you get it figured out. Sorry I couldn't be more helpful... :(
